Diesel Forum - TheDieselStop.com - View Single Post - Jet Fuel A in 7.3's
Old 04-28-2006, 01:02 AM   #14 (permalink)
mjstin
Re: Jet Fuel A in 7.3's
Sounds like he is getting sump fuel from the morning round on the fuel farm tanks and the refuel trucks. If it is they pull a few cups of fuel out of the bottom (sump) of the tank to remove any possible water from the nights cold air condensing inside the storage tank. I used to get it from the big FBO at LAN.
If he's getting the sump fuel from the aircraft you better make sure you filter the water out. Usually there is at least a pint in the tanks but on ocassion I've seen several gallons of water come out of the fuel tanks before you get any fuel and it all gets dumped the same waste fuel barrel.
99.5 4X4 CC dually, 203 t stat, BTM, HX crossover, sonnax tricum.
mjstin is offline   Reply With Quote
