Diesel Forum - TheDieselStop.com - View Single Post - Jet Fuel A in 7.3's
Old 05-08-2007, 06:31 PM   #30 (permalink)
jlrsn
Re: Jet Fuel A in 7.3's
Taking fuel samples from low points in the fuel system is a given, especially with large aircraft, but as an IA you should be aware of AD Notes stating that some GA Aircraft can have gallons of water in their fuel tanks even after sumping until a specific procedure is used or a modification of the fuel system is complied with to be able to remove the water. Even a bladder fuel tank with wrinkles on the bottom from poor installation can retain water after sumping. Enough said, we're getting off topic.
Jim
2000 F250 SD Lariat, SC, SB, 4x4, 7.3L PSD, 6-Spd ZF, 8,800 GVWR, 20,000 GCVW, Reese Class-V Tow Beast Receiver Hitch, Prodigy V2.6, 4" MBRP Stainless Steel Exhaust, AIS Induction Air Filter, AutoEnginuity
2002 26' FT2200 Weekend Warrior Toy Hauler, 102" Wide-Body, 11,100 GVWR, Reese Titan 14,000 lb Trunnion Heavy Duty WD Hitch, DC HP Sway Ctrl, Onan 4BGE-P Emerald Plus GenSet
jlrsn is offline   Reply With Quote
