Re: Lance ELectrical Hookup
Awesome, helpful post! I went and finished my installation (barring two things) this weekend. I disconnected the factory plug at the trailer wiring near the bumper, and probed it to find out which wires did what. Hooked it up, hole-sawed the female end in, and voila! Super-simple. EXCEPT.....
I believe the wire color in the harness running inside the left frame rail is orange (also should be heavier gauge than the rest in the bundle). The relay goes in the small 2-relay box under the hood next to the fuse panel. It's the one (box) closest to the firewall. Don't remember which one is the power relay (other is for backup lights IIRC), but you should be able to track it down with a test light. You'll also have to install a Maxi-fuse in fusebox for the circuit that feeds the relay.
I have no power in the orange wire. THe relays are in place. So, I figure it must be a maxi-fuse. I am missing one maxi fuse in the box. However, since I do not have an owner's manual, I have no idea what the numbers on the box lid actually coincide with, and what amperage they should be.
WHat maxi fuse runs the aux. trailer power? What amperage should it be?
