Diesel Forum - TheDieselStop.com - View Single Post - oil leak from dipstick tube at oil pan
Old 05-22-2006, 12:10 PM   #1 (permalink)
HNLaRue
HNLaRue's Avatar
at first I thought the spot on the drive were from the oil filter being loose again. upon closer inspection it's actually coming from the pan at the place where the dipstick tube leaves the pan.
looks like a big NUT and it is loose to the touch
can you just tighten this up like its threaded into the pan or does the pan have to come off?
I'm going to go hit it with a power washer and then check back here.
99 F350 CC LB 4X4
2001 engine, AFE Stage 2 DP tuner bank chip(tow, economy, 100 and 120hp), 4" turbo back SS exhaust, Ram air hood
HNLaRue is offline   Reply With Quote
