Re: Which coolant?
Simple and quick.
The Gold mixed with a 50/50 water mix only gives 800ppm of nitrite. Bare min protection is 1.2-3.0 with 2.0 being ideal.
I fell for the "GOLD is the wonder coolant" too. I have run it for 20K and decided to test it. Sure enough it was 800ppm, way to low for me. I had to add the SCA, two bottles to bring it up to 2.0.
So don't think just because you bought the Gold you are good to go for another 50K, because this is simply not true. Others have tried to tell you the truth, there are way better coolants out there like the Fleetrite ELC it is good for 300K. If you still want to use the gold make sure you keep up with the nitrite level. If you want a coolant that you can trust is OK go with a ELC that is Cat EC-1 approved.
your choice just know what you are getting into!!!
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
