Re: Which coolant?
Houndog,
If you buy a coolant make sure it has the required Supplemental Cooling Additive (SCA)!
SCA's, maintained at the correct level, helps prevent cavitation of your engine. If you're unfamiliar with cavitation PM me and I'll email you a lot of good reading.
I personally use Low Silicate Fleetguard P/N CC2835 ES Compleat Extended Life Propylene Glycol Antifreeze/Coolant 50/50 Premix containing organic acids that provide superior diesel engine protection by preventing liner pitting, corrosion and scale. It contains DCA-4 brand SCA's.
Fleetguard recently changed their name to Cummins Filtration. Fleetguard products are available worldwide and if interested you can call their North American Customer Assistance Center at (800) 223-4583 to find the closest distributor to you.
Good luck,
Jim
2000 F250 SD Lariat, SC, SB, 4x4, 7.3L PSD, 6-Spd ZF, 8,800 GVWR, 20,000 GCVW, Reese Class-V Tow Beast Receiver Hitch, Prodigy V2.6, 4" MBRP Stainless Steel Exhaust, AIS Induction Air Filter, AutoEnginuity
2002 26' FT2200 Weekend Warrior Toy Hauler, 102" Wide-Body, 11,100 GVWR, Reese Titan 14,000 lb Trunnion Heavy Duty WD Hitch, DC HP Sway Ctrl, Onan 4BGE-P Emerald Plus GenSet
