Diesel Forum - TheDieselStop.com - View Single Post - ?? Mileage towing ??
Old 06-01-2006, 04:15 PM   #17 (permalink)
daveUza
Re: ?? Mileage towing ??
larry brings up a good point..it isn't my truck so i am not to familar with it , but do you RESET the fuel mile part of it each time you want to test for milage? I wasn't sure .. thanks in advance , Dave
1995 f250 XL Ext Cab 4x4, auto ,3.55 gears , 317,000 miles , K&N filter , muffler Deleted ,Shimmed FPR, hypertech chip (a basic older one of unknown power) ,boost guage , small amount of leaf spring work done rest of is stock , steel wheels with hub caps , carpet delete. My old user name was Daveuz , UPDATE AS OF 11/05 new starter new waterpump LEFT ENGINE FAN OFF, new IPR new CPS replaced injector drive (used) all new under the cover harnessess and GPs and all this and my stalling problem was fixed by replacing the PCM , which I had DP Tuner flash in the 80hp econo. 12/28/05 cleaned the Cat Box UPDATE 12/06 334,000K NEW NEW NEW 11/06 1997 xlt CC LB 4x4 all white with a with topper. 285K all stock.
daveUza is offline   Reply With Quote
