Re: Not sure what this is??
Is your truck mad at you or something.....Who knows? My best guess would be moisture in the air.... Just a few days ago after all that rain and warm weather come over here in Indiana, humidity built up in the air with fog...My rig did not start till after the 3rd try. I usually dont try starting again if it dont start the first time til after I waited 30 sec to a minute and restart starting procedure.
but since your tranny did what it did I might would consider replacing the tranny fluid. But it sounds more like moisture affected your electrical components on your rig. So that may be the cause.
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
AmaMoparmanbutlikeForrrrrdtrucks
