Diesel Forum - TheDieselStop.com - View Single Post - Loss of injectors when cold
Old 06-01-2006, 02:34 PM   #5 (permalink)
Ford06
Re: Loss of injectors when cold
You are driving an 03, have you had the wiring harness upgrade?
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, 200 amp large frame alternator replacement, 2 batteries; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors and replaced brake pads for 1st time 1/7/12 101K miles
Ford06 is offline   Reply With Quote
