Diesel Forum - TheDieselStop.com - View Single Post - FAQ: Popular Modifications You Might See Referenced on the Forum
Old 06-08-2006, 12:32 AM   #14 (permalink)
garyt
My Photos: (18)
Re: FAQ: Popular Modifications You Might See Referenced on the Forum
Please be aware! If you are tempted to ask which brand or variant of a mod is best, don't be offended if most of your help comes from vendors and/or sponsors. Most truck owners don't methodically install, test, and then remove a long series of different brands of the same mod. This sometimes happens, but so rarely that you are unlikely to gain the attention of the two or three people in the world who are likely to have the applicable experience to provide a pertinent response to your question. If you manage to get in contact with such a truck owner, be prepared to receive a biased opinion. The only people of whom you may maintain a realistic expectation of intimate familiarity with more than one or two brands or versions of a mod are the vendors and/or sponsors. The only way to find out whether a vendor is biased or straight-shooting is to get to know them.
Mod Name: CCV Mod
Mod Difficulty: Easy to Medium (depends on how much you want to spend)
Tools Required:
Time to Perform: 30-45 Minutes
Mod Description: Crankcase Vent tube is rerouted from the
air intake to a small canister that traps oil residue. There are
several options for this mod ranging from a pre-built kit to doing it
all yourself.
Helpful Links: <font color="red"> CCV MOD THREAD </font>
Mod Name: AIH Mod
Mod Difficulty: Medium
Tools Required:
Time to Perform:
Mod Description: Air Intake Heater is removed to improve intake airflow.
Helpful Links:
Mod Name: Clear Headlights for 1994-2003 F250/F350/F450/F550
Mod Difficulty: Medium to Hard
Tools Required:
Time to Perform:
Mod Description: The clear lens headlight assemblies from
2003-2007 F250 and up trucks will work with no modifications. The
clips on the back of the headlight assembly are supposed to slide
straight up to allow removal of the entire assembly. Some have found
that it is easier to remove the entire front fascia (grill, backing,
etc.) as the clips are sometimes difficult to remove. Another
suggestion is to remove both batteries to gain better access to the
back of the headlight assemblies and therefore the clips.
Helpful Links:
Mod Name: ZooDad or Zoo-Dad
Tools Required: Hole Saw Drill or Dremel-type Tool
Time to Perform:
Mod Description: Hole(s) are drilled in fascia backing plate to
allow more/better airflow into airbox.
Helpful Links:
Mod Name: IC Foil Wrap Delete
Tools Required:
Time to Perform:
Mod Description: Intercooler Foil Wrap is removed to increase turbo
spooling sound. No known benefits to performance except maybe a
small weight savings [img]/ubbthreads/images/graemlins/smirk.gif[/img]
Helpful Links:
Mod Name: Hood Insulation Removal
Tools Required:
Time to Perform:
Mod Description: Insulation on inside of hood is removed to increase
turbo spooling sound. No known benefits to performance except maybe
a small weight savings [img]/ubbthreads/images/graemlins/smirk.gif[/img]
Helpful Links:
Mod Name: 18K Mod
Mod Difficulty:
Tools Required:
Time to Perform:
Mod Description: Judging by the name, something to do with an 18K
resistor.
Helpful Links:
Mod Name: IDM Mod
Mod Difficulty:
Tools Required:
Time to Perform:
Mod Description:
Helpful Links:
Mod Name: 2WD Low Mod
Mod Difficulty:
Tools Required:
Time to Perform:
Mod Description:
Helpful Links:
Mod Name: Always Bright Overhead Console Mod
Mod Difficulty:
Tools Required:
Time to Perform:
Mod Description:
Helpful Links:
Mod Name: AIC Mod
Mod Difficulty:
Tools Required:
Time to Perform: 1-2 Hours
Mod Description: Auxiliary Idle Control (High Idle) will allow you to
manually set and adjust the idle speed of your 1999-2004 PSD truck.
Helpful Links: <u>Forum Post</u>
Mod Name: DP Tuner Lighted 6 Position Switch
Mod Difficulty:
Tools Required:
Time to Perform:
Mod Description: Allows you to easily, and quickly, see what
setting you are currently running on.
Mod Name: "Key-in-Ignition" Door Dinger Delete Mod
Mod Difficulty:
Tools Required:
Time to Perform:
Mod Description: Removes that annoying dinging sound when your
key is in the ignition and the door is open.
Helpful Links:
I added in a CCV mod thread. It has Subman's post that has a lot of popular CCV mods
gsryT
2002 250SD,4x4,XLT crew,6Spd.,4"ATS exhaust,ATS housing,SP Intake,,Edge Evo, Southbend CLutch CON OFE,BD short shifter, ITP Boost Regulator, Warn Preminm Manual Hubs.
DYNO: 325 hp 728 ft lbs
garyt is offline   Reply With Quote
