Mod Name: CCV Mod
Mod Difficulty: Easy to Medium (depends on how much you want to spend)
Tools Required: Screw driver for removing screws that hold doghouse breather to valve cover, new o-rings to replace those between breather and doghouse if yours are worn/stretched, and whatever tools necessary to assemble your mod the way you choose to do it (hose, hose clamps at a minimum)
Time to Perform: 30-45 Minutes
Mod Description: Crankcase Vent tube is rerouted from the
air intake to a small canister that traps oil residue. There are
several options for this mod ranging from a pre-built kit to doing it
all yourself. Also can simply route to the atmosphere: reverse CCV breather dog house that is on driver side valve cover, connect length of clear vinyl or heater hose to the existing elbow via a barbed connector and hose clamps, then route hose up and over brake master cylinder and down along frame rail to your chosen point of termination for the hose. Replace the CCV return piece in the intake tube with a small piece of 4" exhaust pipe.
Helpful Links:
ryaneverk2 webshots album, includes CCV mod pics for vent-to-atmostphere method
Subman's post listing links to various homemade CCV setups
Added some info here, as well, so you can sub this one in place of the CCV entry in your original post.
Also, haven't checked but the link garyt supplied above maybe be a link to Subman's post that has links to about 6 different CCV mod setups, and that link would be very good to add to this CCV entry.
edit - I included the link I was referring to of Subman's in my CCV entry above.
Ryan Arthur
2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
Performance Mods: ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator and tee, ATS ported housing, Banks Big Head, CCV Mod, DP-Tuner flip chip, BTS valve body |||
LEDs everywhere: taillights/running boards/mirrors/rear, side lights wired as turn signals, upgraded headlight harness w/ Xtravisions,
aux backup lights in bumper |||
Misc. Mods: no more dingers, newer cupholder, fumoto, C-Betrs, locking fuel cap, mud flaps, wannabe air horn, Line-X, behind-seat storage shelf, intercooler foil wrap removed, SS HPX
My Truck Pics
NorCal Powerstrokes
