Old 06-09-2006, 10:23 AM   #19 (permalink)
twobit
Re: FAQ: Popular Modifications You Might See Referenced on the Forum
Mod Name: 2WD Low Mod
Mod Difficulty: easy
Tools Required: a switch & wire cutters, crimpers, tape,ect...
Time to Perform: less than 1 hour
Mod Description: for trucks with ESOF 4x4; gives you a 2wd low gear to slowly move heavy trailers in reverse or forward without straining/overheating the automatic transmission. Accomplished by installing switch in center wire of three wire plug on the hub soleniod located on passenger side fender inside hood. Result is transfer case will go into low range (when dash switch is placed in 4LOW) but the auto hubs will not lock the front axle.
Helpful Links:
2002 F350 4x4 CC DRW Lariat 7.3 auto 4.10 LS diff.(bought 5-05 @ 76,000 miles) Pyro, Boost, and Trans gauges. AIH delete. Tru-Cool Max trans cooler. Magnafine filter. Royal Purple MAX synthetic ATF. 55 gallon aux bed tank. 2LO Mod.
2002 Holiday Rambler 30-SKS Alumascape fifth wheel
24 foot gooseneck livestock trailer
1940 McCormick Deering restored Farmall H, used weekly (the grand-daddy of International)
Used goats for rent
twobit is offline   Reply With Quote
