Diesel Forum - TheDieselStop.com - View Single Post - FAQ: Popular Modifications You Might See Referenced on the Forum
Old 06-09-2006, 06:19 PM   #23 (permalink)
Ford_Forgotton
Re: FAQ: Popular Modifications You Might See Referenced on the Forum
Mod Name: 10K Mod
Mod Difficulty: Easy to Medium
Tools Required: 10,000 ohm Resistor, soldering iron, solder.
Time to Perform: 10 mins to 1 hour depending on variation used.
Mod Description: Insert a 10k ohm resistor across the ICP sensor to fool the computer into boosting injector oil pressure. Makes the computer think the HPOP and IPR are low and increases output.
Variations: Variations include Adjustable 10k mod, 18k mod, Diode Clamp Mod.
Helpful Links: Ford_Forgotton's 10k mod page
Mod Name: IDM Mod
Mod Difficulty: Difficult to Very Difficult
Tools Required: Soldering Iron, Solder, Sealant, Hand Tools
Time to Perform: 1 hour to mod, 24 hours to cure sealant
Mod Description: Originally invented by Joe_Servo. Remove a resistor inside the IDM and replace it with a higher value. Increases the injector driver module output voltage from 110 volts to around 135 volts. Extreme caution encouraged. Damaged IDMs are expensive to replace.
Helpful Links: Ford_Forgotton's IDM mod page
Ford_Forgotton is offline   Reply With Quote
