Re: FAQ: Popular Modifications You Might See Referenced on the Forum
removal?! I put one *ON*. Saves the paint from underhood heat.
But, if you want to remove it, its pretty easy. Use a skin wedge, or a door panel removal tool and jam it under all the plastic push tabs that hold it to the hood. Pry them out and off it comes. You may need to play with the hood light a little bit to feed it out of the hood blanket, but its all pretty easy. 10 min job?
