Diesel Forum - TheDieselStop.com - View Single Post - OK, what stupid obvious thing am I missing?
Old 06-12-2006, 04:12 AM   #6 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Re: OK, what stupid obvious thing am I missing?
Yes, the switch is inside the door connected to the latch mechanism. When mine went bad, I knew exactly what to reach for. Just stick the nozzle into the latch where the striker bolt goes and let fly. Don't be stingy with the WD-40. Should fix you right up.
Hard or no-start? Check Here
