Diesel Forum - TheDieselStop.com - View Single Post - pinion seal leak HELP
Old 06-12-2006, 09:26 PM   #2 (permalink)
budman451
Re: pinion seal leak HELP
On a dually, you only have to make an alignment mark on the driveshaft to yoke, remove the driveshaft, yoke, and replace the seal. Then reinstall the yoke, tighten the nut to 400-some ft. lbs. and reinstall driveshaft. Usually when I have done it however, I just use my good 1/2 or 3/4 impact, I don't even bother with a torque multiplier or trying to get out the 3/4 torque wrench. The pinion bearings are setup with a spacer to limit preload.
I have also seen on here frequently that most people have only paid around 100-140 bucks to have it replaced. I would recommend to check what your dealer will charge, and with that you should also get a warranty should it start leaking again after a short term.
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
My Truck
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline   Reply With Quote
