Diesel Forum - TheDieselStop.com - View Single Post - How do you replace driver side headlight?
Old 06-13-2006, 12:31 PM   #4 (permalink)
taxgod4u
Re: How do you replace driver side headlight?
if the same as an 01 should be 2 metal clips in the top rear of the light. they are bent at a 90 degree angel so you can grab them and pull up about a third inch. the light should fall to the ground, hopefully being stopped by the wires so get ready to catch it.
All things in Moderation accept ACCELERATION!!!!
Zip ties... the duct tape of the new milenia!
truckosaurus
2001 F250 Crew, 25,000+ miles, PSD, 4X2, ProComp 6" lift, Short Bed, SCMT, Tymar set up, BTM, ISSPRO Pyro, boost, and Trans Gauges, in tank mods and harpooned, 28" air horn w/ on board air and tank also full set of train horns! 6 gallons of 150 PSI air. Prodigy, Draw tite Signature series 18K 5'r hitch. TTM
2005 wildcat 29RLBS 5'r, parallel EU2000i's
2003 Explorer, EddieBower, V8 4X4
2003 Explorer XLT, V8 4X4
2002 XR50
2001 PW50
taxgod4u is offline   Reply With Quote
