Re: Successfully installed a 1999 F-350 cluster gauge (with tachometer) in my 1997 PSD E-350 van.
Bill,
I like that a lot. Time to hit the dealer to get wiring diagrams for the F250. I can see that making the 4x4 and 4x4low lamps work would be straight forward but how did you get the Low Fuel to work? Is the circuitry to turn it on included in the cluster or is there another connection to the ECU required?
Another question: The F250 cluster that I have came from a truck with a manual transmission so there was a blank insert installed where the gear selector indicator is normally located. In your installation, did you use the indicator from your van or the one from the F-truck?
1998 Quigley E-350 7.3, Webasto ThermoTop heater, quad batteries, TranferFlow 46 gal tank, BD brake.
