Diesel Forum - TheDieselStop.com - View Single Post - Successfully installed a 1999 F-350 cluster gauge (with tachometer) in my 1997 PSD E-350 van.
Old 10-17-2006, 11:26 AM   #7 (permalink)
MADVAN
My Photos: (10)
Re: Successfully installed a 1999 F-350 cluster gauge (with tachometer) in my 1997 PSD E-350 van.
aster
PM me a fax # i will send some notes on the install. I tried to scan but will not work. My cluster was a 2000 and installed in a 1997. The low fuel lamp is a freebie, it works from in the cluster off of the resistance of the fuel level gauge. As far as the trans indicator the blank pops out and yours pops in. You have to use the clear cover from the van on the f-cluster.
The only real thing to look out for is my 97 cluster lighted up BLUE and the 2000 cluster is GREEN. I also changed everything in dash that lights up from a later model van so now everything is GREEN.
Another pict
http://photos.thedieselstop.com/show...amp;thecat=998
Bill [img]/ubbthreads/images/graemlins/smokin.gif[/img]
MADVAN is offline   Reply With Quote
