Just guessing but the factory tach is fed from the pcm reading signal from the cps, eliminate the cps since the truck does start and eliminate wiring issues between pcm and tach since it does work over 1500rpm. Sounds like the gauge has gone south.
thanks for the tip I will try that and see what happens
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
