Re: power steering pump- on board air
what about if you take a single sheave pump pulley--and weld it to the front of your serp pulley--skip weld it at even spots so it doesnt go out of balance----- [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] some may tell you this wont hold---right--your welding on the od of the pulley--also--so you can get this off later on--take a hole saw-- 2 1/2 inch--and bore a hole in the exact center--again so it doesnt go off balance--this will be enough to get the puller thru to get a hold of the recess area---
