Re: power steering pump- on board air
I have the combo serp/vbelt pully from Kilby at onboardair.com.
It replaces your ALTERNATOR pulley and your compressor mounts next to the alternator.
If you're going to drive the compressor off of the power steering pump, the kilby/onboardair.com pully will NOT work for you as it's not made to work on the PS pump (too small a serp diameter).
For alternator drive: Do not order the Kilby overdrive pully as its' serp diameter is much too small. I ordered the O/D one first and had to send it back. Just order the standard pully and it will still overdrive your alternator (and give you more juice at idle) as it is a slightly smaller then stock diameter.
Good luck, Mark
