Re: Tach not always working ..?
the tack has a connector on the back that plugs into the circuit board,sometimes over time the contacts get corroded and must be cleaned ....robert
1989 ford f-250 4x4, new DAS remanufactured 7.3, zf 5 speed- 410 gears, 600.000 + miles,hypermax turbo+exhaust system, air lift air bags all the way around,luk single mass flywheel,york on board air compressor and tank,recaro leather bucket seats,spray on bed liner, holly red pump,coolent filter,gear vender,filtration solutions oil bypass filter,ford motorcraft glow plugs,mechanical gauges in the stock cluster, mean green starter,hypermax cowl air induction system,vormax fuel filter, grover air horns,evans coolant,baja block drains.
Pictures: http://photos.thedieselstop.com/show...1&si=robertleo
