Getting ready to replace GPs
Oil and filter changed - used Rotella 15w40 and a Fram Oil filter. Let me know if the Fram filter was a mistake.
Coolant changed- The PO who owned the vehicle for 2 years and 14k miles used regular antifreeze, no SCAs present. Flushed system with distlled water. Used 2 gallons Zerex precharge (green) and 2 gallon regular green antifreeze with 2 pints of DCA4. Will test later this week. I lost my color card for the test strip kit already. :-(
Will replace autolite glowplugs with Motorcraft ZD-9 that I purchased from Autozone for $9 per plug, which seemed reasonable.
Some questions on changing Glow plugs:
How do you manually turn the engine? I have to guess that manually turning a diesel engine must be tough (and possibly dangerous) due to high compression.
Please describe exactly, what tool to use, where to connect it, should I be disconnecting any belts?, disconnecting any electrical connections (battery, ...)
Is there a specific spot on the timing mark where I'm supposed to align the harmonic balancer? I'm used to gasoline engines where the timing is set to a specific value like 8 degrees before TDC
Any suggestions on a good book for my truck? Should I just get a haynes manual?
Sorry I'm such a newb, but I would hate to screw up a pretty good running diesel by changing the GPs.
Thanks,
Pigseye
1990 F250 Extended Cab, 7.3L IDI, No turbo, Auto transmission, 215K miles, lots of rust!
1994 F250 Extended Cab, 7.3L IDI, Turbo, Auto transmission, 158K miles, very little rust
