Re: Deep transmission pan questions
Have you replaced the factory cooler with a larger one yet? You will get more from that than a finned pan. There really isn't a lot of flow over the trans pan, at least compared to through the grill of the truck.
I think the previous owner did, although, I am going to look again tonight. Even if it already has an aftermarket cooler, I am thinking of adding another. Is there a specific unit that is offered that is best suited for my truck?
Thanks - Adam
So I looked, and it appears that the factory cooler (in the bottom of the radiator) has been bypassed, and there is now a small cooler in front of the AC condensor that is about 6X12X3/4.
Since the factory cooler is not being used, can I install a 2nd auxillary transmission cooler, or should I purchase a larger transmission cooler with fan to replace the existing non-oem cooler?
thanks in advance,
Adam
