Changing motor mounts
Hi guys,
I'm about 65 miles away from my truck & manuals. it appears that the driver's side motor mount is broken, I followed advice from awhile ago & finally got somebody to look at motor in gear while I gave it some throttle & the driver's side appeared to raise [img]/ubbthreads/images/graemlins/bleh.gif[/img]. So does someone know of a 'safe' point to jack on the engine to lift it enough to replace both motor mounts; or do I need to lift the motor with a cherry picker/engine hoist and do I need to loosen the E40D trans mounts to accomplish this.
I have a very short time to accomplish this this weekend, as my wife is still in the hospital parts will arrive probably today I won't be able to pick them up until Saturday morning.
Thanks, jerry
'91 F350 CC,7.3NA w/K&N,E40D(rebuilt--way too many times), 2WD,3.55 rear end,new IP,new u-joints & carrier bearing, new rotors, new calipers, new drums & hdware, added Auburn limited slip unit (2/8/05)w/valvoline synth 80-90w, new batt.cables,new window motors,new radiator & hoses, 500K, (new injectors)+ mi (now 678K miles)& still Truck'n. If I can fix it, it ain't broke, I'd rather do it myself.(yes, I add,stanadyne, lucas or power sytems fuel additive in every tank, w/maybe 1-2x year full big bottle dose split between both tanks). New tires & pretty wheels, front end rebuild 3/17/05. Bilsteins added 6/12/05. New motor mounts & valve cover gaskets (9/06.)Future hopes finally fixing my electric door locks & adding remote entry/alarm system.
http://community.webshots.com/user/jl_mendoza
