Re: Changing motor mounts
Thanks everyone for your responses, I think I will try the jack & 2x4 method on each side of the oil pan. Hopefully that will git'r'done in short order without too much brain damage.
Doing it that way how long did it take you? (dsblack)
jerry
'91 F350 CC,7.3NA w/K&N,E40D(rebuilt--way too many times), 2WD,3.55 rear end,new IP,new u-joints & carrier bearing, new rotors, new calipers, new drums & hdware, added Auburn limited slip unit (2/8/05)w/valvoline synth 80-90w, new batt.cables,new window motors,new radiator & hoses, 500K, (new injectors)+ mi (now 678K miles)& still Truck'n. If I can fix it, it ain't broke, I'd rather do it myself.(yes, I add,stanadyne, lucas or power sytems fuel additive in every tank, w/maybe 1-2x year full big bottle dose split between both tanks). New tires & pretty wheels, front end rebuild 3/17/05. Bilsteins added 6/12/05. New motor mounts & valve cover gaskets (9/06.)Future hopes finally fixing my electric door locks & adding remote entry/alarm system.
http://community.webshots.com/user/jl_mendoza
