Re: F450 Lift
I'd still think just use whatever axle you can find, use 2 different wheels or go aftermarket since you're lifting it. I'm sure there might be hub systems out there that will change your bolt pattern.
Also, maybe switch both of the axles out from a newer F4/550?
2001 F250 Platinum Edition
Hybrids, 38R, Studs, Springs, Forged, etc...
12 second crew cab
