Timing IP in Houston,TX?
Does anybody know a good shop or mechanic in Houston,TX that can do dynamic timing? Just replaced my IP with one from DIS and truck seems to run good(my special "by the ear" timing using my special "ground thin" custom wrench). I called 2 Ford shops and they said it will take 2 hours and they might have to deal with other stuff like being off a tooth on the gear (never pulled the gear cover)! I told the servive writers that there is nothing to do except just set the timing. I don't want someone "playing" with my IP just to make more money. The IP is warrantied by DIS and already set to specs (and sealed to indicate tampering) If they loan me the equip. I would do it in their parking lot in less than 30 minutes. Other shops I called don't have the timing equipment. Need to set timing by Saturday Aug. 5th (going out of town).
Anybody got any ideas or know somebody that can help?
Thanks in advance.
1990 F350 4X4, Crew Cab, LWB, 7.3L naturally aspirated diesel, E4OD transmission, 3.73 gears, manual lock-out hubs, converted 134a A/C & 330,000+ miles. I do the maintence myself and add fuel.......it just keeps going and going and going.
