Re: E4OD High shift points
Lower voltage will give lower shifts.
If you need to use lower voltage, install a "pressure riser" to keep the hydraulic line pressure up or you will burn out the trans clutches. http://www.oregonperformancetransmission...egory_Code=E4O D
*ASE Master Certified, Medium & Heavy Trucks*
