Re: FIPL Sensor (TPS) Replacement
Torx screwdriver set or socket set in smaller sizes #15 comes to mind. You can use the larger bracket bolts if required 7/16-9/16 and metric wreches.
FIPL set to specs:
With a warm engine and the idle speed set to your engine specs probably 650 in drive (curb idle).
Now with key on engine off. First connect the negative lead of a volt meter to the negative battery post, then place a paperclip straightened to slide up the side of the center wire for a good contact, touch the positive lead to the paperclip. Electrical connector must beconnected to the FIPL.
If your FIPL requires resetting loosen the small torx screws and attempt to attain the correct setting. You can loosen the large bolts on the bracket if necessary but try to retain the centering on the FIPL/blade.
Your trying to get closed throttle voltage: 1.1 V, wide open throttle voltage: minimum of 3.8 V but not more than 4.3 V.
If you can attain those #s then tighten the screws/bolts and ensure the voltage is at the correct setting after tightening. You can also do a slow sweep of the fuel lever from idle to WOT to see if there are any blanc (dead) spots, much easier with a really $$$ meter with capture mode. If you still find there are hard shifts or very soft slippery shifts you can adjust to suit your driving but be warned slippery shifts will burn the trans up.
<font color="purple"> Check your email.... </font>
Proud Canadian BOOB man too!!
