Re: How much weight in the bed?
I don't know how much it weighed, but during a flood here three years ago I had the bed completely filled with sand bags...enough that they started falling off because they were stacked so high. I have the blown out bedsides to prove it. It was a LOT of weight but I have different springs than factory. Steered like the front end was off the ground though... [img]/ubbthreads/images/graemlins/smokin.gif[/img]
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
Member of Indiana Air National Guard 122FW MXS
