Re: How much weight in the bed?
Are the frame and suspension very similar between the F350 and E350? Which carries more weight right out the show room floor? I'm talkin model year 1989.
88 E350 7.3 C6 154k
done: Remanufactured Inj pump, New Stanadyne injectors, Michelin M/S tires, ShellZone AF & Fleetrite SCA, replaced and relocated fuel filter assembly, elec fuel pump, no flying saucer, return lines/ o-ring kit, new heater core, 8 Beru glow plugs, oil & filter, stabilator on sliding door (plastic slider cracked in half)
Hot compression readings:
2. 500 1. 500
4. 460 3. 420
6. 540 5. 465
8. 480 7. 540
to do: transmission fluid, fix rust spots, WVO conversion.........
