Diesel Forum - TheDieselStop.com - View Single Post - rear ride height
Old 08-14-2006, 01:27 PM   #6 (permalink)
johnson1
Re: rear ride height
You can use the blocks from a F250 and original U-bolts (since you
will be farther into the threads).
Call some 4 x 4 shops for the blocks. They sould have some (mine were free) off of lifted trucks.
You'll find your truck rides better empty but will sag when loaded.
Then you need air bags.
2008 F350 Lariat, 4 x 4, 6.4, Torque Shift, 3.73 Dark Blue Pearl,CC Long Bed. Bought Feb. 2007.
Traded 2003 F350 Lariat, FX4, 6.0, Dark Shadow Gray, Torqshift, CC, Longbed, Jan., 03 build, Velvet Ride shackles.27 ft. toy box
3 Injectors
Fuel Pump, rear main seal, front crank seal, 2 rear pinion seals, numeros sensors, 2 EGR valves,
3 turbos.
& other misc. repairs
johnson1 is offline   Reply With Quote
