Diesel Forum - TheDieselStop.com - View Single Post - Replacement Muffler
Old 08-09-2006, 08:50 AM   #2 (permalink)
Mark Craig
Re: Replacement Muffler
TexasTruck,
You can rig up a few mufflers out there to work, but the look and fit and finish will be less than great as the stock muffler is a low in high out and all the performance mufflers use a straight thru design. Your best bet is to get a cat back from someone like us and go from there. They are pretty inexpensive overall and will flow a lot better than the stock pipes too as the stock pipes are smaller in diameterand non mandrel bent. Take a look at the tail pipe as it goes over the axle and compare it to a MBRP ro AFE systems, much lower, smoother and better flowing etc. If you have any questions let us know.
Mark @ DPPI
Mark Craig is offline   Reply With Quote
