Re: Anyone Blow a 6.0 Head Gasket Yet?
HELLO JUST1MORE
I am on my 3rd set of head gaskets including the original ones make sure thy do not surface the heads on your truck because their is no clearance for a shaved head the values will hit the pistons or as mind did it will cause the injectors to burn up because of the compression If the heads are warped they must install new ones
07 F-250 6.0 L CC XLT 4x4 Red Addons: ARE Cover, WheelSkin Cover, PML Rear axle Cover, Dieselsite Coolant Filter, C-better Mirrors,Gauges Isspro Fuel press. Trans Temp. EGT gauge. Gauges from Diesel Manor. Edge Insight CS (For EOT & ECT)
04 F-250 6.0 L CC XLT 4x4 White Buy Back
...... 06 Jayco Travel Trailer 32'
