Diesel Forum - TheDieselStop.com - View Single Post - Anyone Blow a 6.0 Head Gasket Yet?
Old 08-10-2006, 09:26 PM   #18 (permalink)
rocky7184
Re: Anyone Blow a 6.0 Head Gasket Yet?
I'll second that. Layered steel head gaskets do not "blow" the way composite gaskets do. Coolant really cannot leak into the cylinders because the cooling system does not have enough pressure to do so.
There is still enough pressure on the gasket to form a seal. When the head gaskets fail to seal effectively, they leak combustion into the cooling system and force coolant out of the de-gas bottle. You may have steam coming from under the hood but no billowing smoke.
Ford_Doc
Does coolant blowing out of the de-gas bottle usually signal a head gasget issue? It happened to me recently. Also, what does a dealer do to test for head gasket issues?
Hey Clevelandjim same thing happened to me.Turned out to be a bad cap on the degas bottle.The dealer also lowered the level in the bottle(per recall notice).
They did that in feb or march and i have not had any issues at all.I've also towed about 6,000 miles with a 7,000 lb camper and haven't had another leak from the bottle.
2005 f250 cc Lb 2wd PSD
rocky7184 is offline   Reply With Quote
