Re: Fuel leaking
While I was at the dealer getting the filters changed they mentioned I should have a 45000 mile injector cleaning to make sure my 100000 diesel engine warranty stays in effect too.
Ask then to show you were in the engine warranty fine print that "injector cleaning" is required to keep your 100K mile engine warranty valid. It could probably be found under the snake oil clause....
And just what do they do to "clean" the injectors? Take each one out and give it a little bath with Johnson's baby soap and a rubber ducky?
There's a cute little injectors, let's get you clean up behind your cute little intensifier piston.....
My html Version of the 6.0L Bible Now with 2005 Updates
$5 AIC
Born on date: Jan 20, 2003
Number of times the EGR valve has been replaced/cleaned: 0 (updated: 4/15/2010)
The United States Constitution © 1791, All Right Reserved.
