Re: Fuel leaking
I've had the same problem with my 02 f350. I've noticed if I park it on a downhill slope, no leaking. what gives? I'm just glad it's not oil.
Since you've got a 7.3, I'd take a good close look at the metal fuel line running along the passenger side cylinder head. It goes through a metal bracket under the turbo, and the braket will wear into the line and cause a fuel leak. It only leaks wit the engine running. If you park it on a downhill slope, the fuel will flow away from the drain hole in the back of the block.
What sig?
