Diesel Forum - TheDieselStop.com - View Single Post - Can a brake stand launch cause harm?
Old 08-14-2006, 03:13 PM   #17 (permalink)
Ford06
Re: Can a brake stand launch cause harm?
I have a question concerning this post. I drove my friends 6.0 and his was a dog off the line. My 7.3 will litterally burn circles around his. We tried every kind of launch and it will not break the tires free. You can hold the brake and WOT and it just sits there. Once you let off the brake, it starts going but really picks up after the first 30ft or so. I was expecting a little more wow. If you step on it from a dead stop with no brake, its like "yawn" for the first couple of seconds. It has plenty of power while driving, but it definitely has no get up and go. Is this normal or is he having some sort of problem. It is a stock 05. From the previous post, it sounds like a stock 6 has no problem lighting them up.
Unfortunately my 06 is like that as well. [img]/ubbthreads/images/graemlins/frown.gif[/img]
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, 200 amp large frame alternator replacement, 2 batteries; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors and replaced brake pads for 1st time 1/7/12 101K miles
Ford06 is offline   Reply With Quote
