Re: Tranny and Torque Converter Questions
As usual Greg, thanks for the assistance.
As far as drive line angle goes, I bought a CV Driveshaft for the rear as soon as it was lifted. I then had a set of blocks machined for the rear that pitch the driveshaft straight up to the tranny. After all that I thought it was the driveshaft also so I lowered the transmission crossmember an inch and it had no effect. So i took it to a driveline specialist and we test drove it and he said that he would need to keep it for a day to figure it out, but that it definitely wasn't the driveshaft.
Also, the truck vibrates at a red light some times so that is how I came to this conclusion. If it starts to vibrate, all I have to do is tap the gas and the vibration goes completely away.
For example at 53mph if I hold that speed and tap the brake with my left foot, the vibration goes away and the rpm raises to 2100. So I assume that is the torque converter unlocking correct?
Thanks again Greg
2008 F350 CrewCab Longbed, Black on Black, 12 inch Modified Rize Lift, King Coilovers in Front, King Reservoirs Front and Back, 40 inch Nittos, Amp Steps, 4.88 Gears
