Re: possibly buying an 07 6.0, warranty questions
Go in without a cat and 99% of the dealers aren't going to touch it. Removal is a violation of Federal law after all.
As far as the tuner, some dealers are more "mod friendly" than others and will overlook things. That being said, however, if the repair is major it can go beyond the dealer for warranty approval. And you can bet they are not going to overlook the fact that you have a tuner. Ford is also getting a lot better at figuring out if you've had one installed as well. It all boils down to personal choice...I won't risk a $10-15k repair bill for power that I don't "need"
Ford got the intake right on these trucks, not all that much benefit there on a stock or mildly modified engine. But, should you install one and have turbo problems it's up to the dealer if it will be covered.
Cat-back exhausts...very few dealers, if any, will give you grief over that.
Gauges...as long as they are installed properly not a problem there.
2005 F-350 CC SRW SB Auto 4x4 Lariat
