Re: Are we out of the woods????
You drive dodges and you think they last a long time!!
I'm not sure I follow you-are you saying they don't last a long time, or that they DO last a long time? In any case, I can't say I have a dodge with a huge amount of mileage-my '98 only has 265k on it.
1998 Dodge 12v 5 spd 2wd dually, 275k on truck, bhaf, CPP 7x10 injectors, timing at 19 deg, 3k gsk, no fuel plate, htb2 64-13 turbo with stainless exh housing, wastegate set at 50 psi, southbend dual disk clutch, detroit locker, has broken 2 stock dana 80 limited slip units, has run 14.65 at 98 granny shifting the 5 spd, dynoed at 450 hp and 906 ft/lbs on REALLY STINGY dyno
