Re: Can't find 2007 upfitter switch wires / SEIC advise
They are on top of the fuse box and tough to get at without remove the fuse box itself. Remove the access panel, remove the four bolts, and pull the fuse panel out and down. You will then find the upfitter wires.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
