Diesel Forum - TheDieselStop.com - View Single Post - Oil Filters
Thread: Oil Filters
Old 08-21-2006, 07:27 AM   #13 (permalink)
sicaj
Banned
Re: Oil Filters
I have purchased and used oem 6.0 oil filters and amsoil filters, seeing both oem/aftermarket then an amsoil filter anyone that has two good working eye balls and half a brain can tell wich filter has superior cababilities from ten feet away.
[/ QUOTE ]I used the amsoil filters as soon as they were released.I left it in for 3000 miles ,then removed for inspection.I found this filter collapsing in the middle.I called amsoil.They told me it was probally becuase the filter is so effective.I asked ,Doesn't this effect flow of oil?The response I got was,If your oil pressure gauge is reading normal,there isn't a problem .I sent the filter back to them for inspection.I WILL NEVER USE THIS FILTER AGAIN!I think it empedes the flow of oil.What do you have to say to that,BUSE?aka al's parrot [img]/ubbthreads/images/graemlins/bleh.gif[/img]
you said u used it only 3k and it collapsed? did u use amoil oil? did you happen to take a pic of the filter, was it a EaA88 filter? how long ago did that happen to you?
[/ QUOTE ]Are you for real???.I didn't use the correct filter [img]/ubbthreads/images/graemlins/rolleyes.gif[/img].As I said in my previous post,I spoke with amsoil about it.If you have anymore questions,contact them.Also,when you use amsoil filters,you have to use amsoil oil??GET REAL DUDE?How many brownnie points do you get from "Al" for these posts?PARROT .POLY WANT A CRACKER??[img]/ubbthreads/images/graemlins/eek.gif[/img]
sicaj is offline   Reply With Quote
