Re: Oil Filters
[quoteyou said u used it only 3k and it collapsed? did u use amoil oil? did you happen to take a pic of the filter, was it a EaA88 filter? how long ago did that happen to you?
Ok, I will correct him. It should be a EAO88, not a EAA88. They did redesign the filters for the 6.0. It first started out as the same filter everyone else bought. It was not a synthetic media filter then. When AMSOIL switched to the synthetic media, AMSOIL designed there own filter. They actually most recently changed the design again to allow better flow for people using a By-pass system, and retaining the stock oil filter and plumbing through the filter cap and oil fill cap.
"The one I'm using also claims 98%."
When you claim that the one you are using also claims 98%, at what micron is it filtering 98% of? Is it 15 micron, or 25 micron. With the AMSOIL filter, the are the only company that I know of the claims 98.7% at 15 microns.
I am not tring to Hijac this post, just trying to clear some stuff up!
2006 F350 6.0 Auto CC 4X4 DRW LB
White Lariat 4.10 LTD Slip
Line-X, Transfer flow 57 gallon
Firestone Airbags, Colibert Hitch,
Recon lights, Truxedo Cover Edge A2
2004 F350 6.0 auto cc 4x4 drw lb
oxford white
xlt sport pkg.
4.10 ltd slp
aux idl ctrl
hd suspension
tt mirrors power
moon roof
Transfer flow 57 gallon replacement tank
Cap
Line-x spray in
Firestone Airbags
Edge w/juice
Amsoil 15W40
