Diesel Forum - TheDieselStop.com - View Single Post - quick question about leaking exhaust manifolds
Old 08-20-2006, 05:39 PM   #1 (permalink)
jchadw
I have an 06 PSD and I was underneath installing a Mag Hytec rear diff cover and decided to take a look to see if I could find out why when I have the air conditioner on I smell exhaust blowing through the vents. On both exhaust manifolds at almost every exhaust port I have black soot around the manifolds. I would not think that this would be acceptable. From what I can see there are no exhaust manifold gaskets on this motor. Am I correct? I do have a Banks 4" turbo back exhaust but I don't think that this would cause the problem as the manifolds have a flexible coupling between them and the turbo. Because of the aftermarket exhaust is this something that you think I will need to pay for or should it be covered under warranty? Last question, what would the fix be for this?
Thanks in advance,
Chad
2006 PSD Lariat Supercab with Torqueshift, FX4, snowplow prep, camper package, Banks 4" exhaust turbo back, AFE Stage 1 PG7, Goodyear Wrangler MT/R's, Mag-Hytec transmission pan and rear differential cover, pretty much all the interior goodies you could want
1992 Corvette, automatic, aquamarine exterior with black interior, Grand Sport wheels and tires, Dynotec Engineering distributor, MSD coil and wires, GM Rapidfire plugs, open lid K&N air filter assembly, other than that it is fairly stock
jchadw is offline   Reply With Quote
