Re: quick question about leaking exhaust manifolds
Does anyone know how much to torque the exhaust manifold bolts and in what order? Want to drill and tap manifold for an EGT probe and don't want to take a chance of metal chips getting to the turbo. Thanks in advance.
2003 F250 SC SB 6.0 PSD 4X4 Lariat toreador Red/Arizona Beige, torqshift, 20K miles, engine build date: 1/8/03, truck build date: 1/29/03, all flashes except buzz & inductive, Leer cap, Warn front receiver, Spray-in bedliner, A pilar EGT, Boost & Trans Temp Gauges, high idle mod, CB, 250W oil pan heater with Marinco plug, everything else stock. 4 injectors replaced @ 4500 miles;2 VGT solenoids replaced @ 4500 & 8400 miles; EGR,EBP & MAP replaced @ 12800 miles; 2 turbos replaced @ 13700 & 15400 miles.
