Re: Hard Start!
[img]/ubbthreads/images/graemlins/smile.gif[/img]there may be one of two things wrong. one is a short in the drivers side harness running along the top side of the head going to the ficm module where the loom y's off going down to the pcm. at the y section right by cyl. 4 inj. pigtail you want to wiggle in that area while some one cranks the eng. & see if it will start. the other is you may have a high pressure leak in your oil system, blown oring somewhere in that system. those are two of the most common problems for this eng. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
