Re: Run used oil
This gets discussed regularly down in the alt / biofuels fourm.
The best place for WMO is a heater in your shop. There's no way I'd put it in my PSD. Its NOT A FUEL, so why put it in your fuel tank? I wouldn't use ATF, alcohol, piss, MMO, or water either.
This is why Ford will not warranty a fuel related problem. If you had an injector problem and they suspect the fuel was related, they'll deny repair, because they can't control what us idiots pour into our fuel tanks.
An older IDI type engine was/is a different beast, and could take more abuse (and yes, it was abuse) than a PSD (either 7.3 or 6.0).
And if you ever buy a 6.4, don't even think of going there. You'll destroy the smog system post haste.
